James Edward
- May 1, 2000
As my title states, someone I know can barely get enough volume out of her Tivo'd shows that she has taped to VHS.
She is using a Scientific Atlanta cable box-the 4200HD to be exact. The audio output is set to 'fixed'. Should I have her try setting it to 'variable' and raising the cable box volume itself? I know that setting affects the level to the output jacks, so would it also affect the recording level?
As I write this, it makes sense that that would be the case... Any thoughts are appreciated. Thanks.
