ChrisDixon
- Nov 20, 2001
1. Is it OK to place the sub (16-46PC) right in a corner with little breathing room? Due to space considerations, mine is sitting about 2 inches from the side wall and about a foot from the back wall. Since it is top ported, will I still get good results, or do I need to figure out how to give it more space?
2. When I have the sub cross-over disabled, my receiver (Marantz SR-7000) seems to send a full range signal to the sub for it's internal sub test tone. The reason I'm assuming this is that the tone has a higher sound (almost like running water) along with the rumble. If I re-enable the crossover, it's olny rumble. Also, when I use Video Essentials with the cross-over disabled, it is only rumble. My question is, could this fuller range sub test tone damage the woofer? Should I avoid using it this way?
Thanks in advance,
Chris
Thanks in advance,
Chris
