ThomasL
- Mar 13, 2001
This is a question for the ISF calibration experts out there
I've recently revisited the grayscale settings on my tv and I noticed that the Avia vertical ramp grayscale pattern looks different if I have the color setting set to 0 in the user menu instead of the Avia calibrated setting. There is a distinct purplish hue that gets added to the lower end of the scale. I was under the impression that the color decoder should not be affecting the grayscale at all? If it is, should one calibrate the grayscale with the color setting set to minimum in the user menu?
thanks,
--tom
thanks,
--tom
