Ray_C
- Jan 6, 2004
Hello All,
Got a question about the trigger function on a Marantz MM9000 5-channel amp. Bear with me on this one. The amp has an RCA jack for a trigger in that's marked as 'video signal', originally intended for hookup to the composite video out of a TV or monitor out of a receiver. The manual states that this same trigger jack can be used for other trigger signals, from 5V to 13V. I'm using a Denon AVR-2803 as a pre/pro, and its trigger out is a mini-plug (typical 1/8" mini-headphone-type) that's marked as 12V max. Can I use the 2803's trigger out via mini-plug to RCA plug adaptor to control the 'power on' and 'standby' on the MM9000? Thanks in advance.
