To those with Denon Recivers (1 Viewer)
Nate Haley
Any one use their 2802 or 3802 to power 4 ohm speakers?
If so does it have any problems with this speaker load.
I am planning on running two Axiom M22's as a center channel
which should present my 2802 with a 4 ohm load...
jason celaya
you are good to go with either reciever, however it may be best to add a amp whenever you are using low impedance speakers (esp.low sens) .
JoeyT66
