Mike Sloan
- May 18, 2002
I realise that the THX optimiser may be a newer version of the Optimode system....allowing you to optimize the performance of your home theater system for individual DVD titles. They don't specify calibration levels. Others have reported problems.They have recently stated that the Optimode calibration noise should not be used to assess the output levels of a system, although this advice does contradict the original Optimode press release which reads: “THX Optimode provides tests for speaker level, speaker phase and Low Frequency Effects (LFE) channel crossover.”
The reason for THX's change of heart is clear from the results of my own investigations. The THX Optimode calibration noise is inaccurate, in some cases by as much as 10dB. The link I will give you below takes you to a site that further explains that the "optimizer" should not be confused with the "optimode" setup. When you click on setup specifics for the optimizer...it takes you to Optimode....ANY IDEAS?
Optimode
THX Optimizer
Optimode
THX Optimizer
