Sebastian
- Apr 14, 2002
When using VE to calibrate your sub what should this be set at? I have searched for a few post and seems like it is supposed to be in the max position. Which I believe on my rec (onkyo) it is 0 for DD and +10 for DTS.
Up until I calibrated it was 18dB hot. Keep in mind I never listen at reference level.
Well anyway, I adjusted it to 85 dB (10 dB hot) and I feel if I adjust it any lower to 75Db to match the other channels, I would not even hear the LFE!
I have yet to do so because of time constraints.
So this might be a premature post but suffice to say I think I will be lucky to hear the sub adjusted correctly.
Any advice? the meter is set up correctly and has been moved around just as VE advises.
Yes, the speakers are set to small and subwoofer to yes.
