Bill Fagal
- Jul 8, 2002
Chip in with your own pipe dreams and let's hava little fun.
Project 1: Wall of sound
Step one:
Wall off the front third (or about 3000 cubic feet, which ever is greater) of your home theater with multiple layers of MDF, cross-brace it and seal it up. This is your enclosure.
Step two:
visit Orevox and place an order for enough DS-312 12" drivers to completely encrust your new wall. For example, if your wall is 16x8 ft. you'll snap up 128 of 'em. They're less than 9 bucks each, so quit whining. Sure their T/S params stink, but you're overcoming wimpy wimpy quality with hefty hefty quantity.
Step three:
Get busy with your router and circle jig, making homes for all 128 little air pumps. Weary not in well-doing.
Step four:
Mount drivers, wire them series/parallel, and connect them to a modest amp of 250 watts or so, downstream of a LT circuit to flatten the humpiness of the high-Q drivers.
Step five:
Stand back and survey the damage. For about $1200 in drivers, plus modest outlay for lumber, amp, LT circuit, and assorted sundries, you now have a subwoofer with the following characteristics:
A radiating surface equivalent to a single 9 1/2-foot driver that will displace over 2500 cubic inches of air at a mere 1/4" of p-p excursion. (Single-digit Hz? Yes--loudly.)
A baseline anechoic efficiency of over 107 dB/W.
A theoretical anechoic 131 dB at 250W (at which power level each driver will see just less than 2W.)
An eye-popping decor theme!
Step one:
Step two:
Step three:
Step four:
Step five:
