Greg P
- Jan 7, 2001
Arrrrgh!
I got my sealed 1503 up and going about a week ago. I had a problem a week ago which was partly due to my cabinate not being sealed. I have checked as far well as I can by ear and there are no leaks. I still have this bad distortion or tapping at lould volumes, around -10 with bass heavy music. For example I played some rap music to test my new filter setting ( with only 3 filters which sounds awesome this is the best sounding sub Ive ever heard.) Slim Shady (Intro) and the bass will just all of a sudden go to a bad distortion or something. The bass will go from boom, bom, bam(along with the song) to blaaam, bluuum,(basicly sounds like crap, not listenable) and the cone appears to be smacking something. Its just all of a sudden, not like the air leak. My amp is not clipping, nor is the BFD. I have a crest LT-1000 with 1300 watts, so it should not be bottoming out. Could this be a leak really small that Its only noticable, on loud passages, ( I dont think so though because its just happens all of a sudden, it is or it isnt) Is this distortion? Is there any issue with my tad bit higher Q of around .63 or .64 with using the BFD? I really need help guys.
