ross ish
- Nov 18, 2002
While using Avia with the RS meter, I set one main speaker to 75db pink noise. Next, I set the sub to 75db pink noise...do I have to compensate for the RS meter bass by (corrected value) adding 3-5db; or do I just level match 75db with the mains?
Also, once the sub level is set, is there any need to fool with the LFE output of my processor?
Thanks, any info will be helpful.
