Spikes for subwoofer (1 Viewer)
JoelTW
My carpet is relatively thick and my subwoofer enclosure seems to jump up and down really quickly...
Do carpet spikes really improve the sound quality, or accuracy/tightness, etc?
They cost $2.50 at partsexpress. :)
Gabriel_Lam
How heavy is your sub? Will those thin spikes be enough? The $2.50 ones might look kinda funny.
Here they are attached to my old JBL S312 speakers (about 70 lbs eahc):
For subs, you may want to go with the bigger Dayton audio ones (unfortunately, they're another $15 or so):
JoelTW
I think it weighs about 60 lbs... yeah I was wondering why the other ones cost $19.95..
Rob Formica
"Do carpet spikes really improve the sound quality, or accuracy/tightness, etc?"
I don't have any carpet so i can't say for your situation, but i do find rubber-feet versus spikes on a hardwood floor make a big difference in de-coupling the sub. Which you prefer is a question of personal taste... but they give the following "impressions":
Spikes: improved mid-bass
Rubber: improved low-bass extension
My guess is the carpet already de-couples the sub, so you have nothing to loose.
later...
Rob
