Chris Huber
- Jan 2, 2003
Speakers:
JBL PB12 Sub
JBL S-Center-II
JBL S312II front (big 12 inchers)
JBL E10 sides
JBL N24II rears
-My reciever has ability to set (F)ront, (C)enter and (S)urround size (S)MALL or (L)ARGE. It also has the ability to select 100, 150 or 200 x-over settings.
1. My guess would be to set FL-CS-SS for speaker sizes, right? (is that center considered small?)
2. Then where should I set the X-over, 100, 150, 200?
3. The sub has 50-150 dial. After all the above is set, where should I turn the dial to?
Thanks for your help in advance! Any other comments are welcome aswell...
JBL PB12 Sub
JBL S-Center-II
JBL E10 sides
JBL N24II rears
