Rancho5
- Jan 28, 2009
- Alec
I've just completed the wiring for all my speakers in our framed HT. I ran wire for 7.1 and was wondering since I have the extra wire and boxes, what other places might I run wire to to prepare for the future? I do have "behind the wall" access to the front and side walls, just not the rear and ceiling. I did run wires to the "front top L & R" 3 ft above the fronts to be ready for that Dolby z thing.
Where else would you suggest? Ceilings?
I did not run for a 2nd subwoofer as I have an SVS 12" cylinder 31 inches tall and the room is only 22 long, 10 wide and 7 tall, so this sub is MORE than adequate, plus I can always get to the sides if I need to.
Do you think there is any possibility of future ceiling locations?
Also running a pvc pipe from ceiling pj location to AV closet for future use and an ethernet cable to the AV closet.
