John Doh
- Jun 24, 2003
I need suggestions on which speaker wire to use for my HT. My budget is $100 for all speaker wire connections. I need to run my surround speaker wire through the wall, across the attic and down another wall. Do I need a different type wire because I'm going through the attic? Also, I need a wire recommendation for my fronts, but the wire will be ran under the base boards instead of the attic.
My front speakers are JBL S38II's and the surrounds are S36II's. I want a big enough wire quality wire to not hold back these speakers, but my budget is somewhat limiting. Thanks!
