Greg Haynes
- Oct 22, 1998
Looking to sell a 1.5yr old Sony MDS-630 Minidisc recorder. This recorder has low hours on it. No more than 30 hours. I just never got around using it. I still have the remote and manual but not the original box. The item will be boxed very secured. I will also throw in 10 blank Sony Minidiscs. I actuaully might have more if I can find them. If I can them I will add them as well. Asking price is $100. Buyer will pay for UPS Ground actual cost. Check my ebay feedback using ghaynes1.
Features:
The MDS-JE630 is a component MiniDisc recorder/player designed to provide cost-effective digital recording quality, using the popular re-recordable MD format. Although originally made for home audio, it's attractive price-point and impressive feature set make it a useful tool in a number of professional production applications.
24 bit A/D converters using Wide Bit Stream technology
For superior dynamic range.
ATRAC type "R" next-generation bit-reduction shceme
Provides CD-like sound quality
2 Optical Inputs, 1 Optical Outputs
1 Analog Input
A-B erase
S-link, A-1 interface
6 second advanced Time-Shift Recording. Prevents "clipping " the beginning of a recording. Great for recording "off-air"
Standard PC keyboard input
Features:
1 Analog Input
A-B erase
