Yurik
- Jun 20, 2002
Hello all,
I have several questions about SONY wide screen rear projection HDTV
model KDP-57XBR2 I bought recently. First, when I connect my Apex AD-800
DVD player to it via component RGB, a movie shows black bars on top and
bottom of the screen even though the disk is clearly widescreen, DVD player
is set to 16:9 output and the TV is in full wide screen mode. Even though
the bars are much thinner than on my old 4:3 TV, they're still there - what
to do to watch a DVD move in full 16:9 wide screen?
Second, there're couple station that broadcast in HDTV here in New York.
CBS-2 for example on channel 2.1. But even though their picture is HDTV, it
doesn't fill the entire screen there're black bars on the left and right.
Even though the bars are smaller than on ordinary 4:3 broadcast, they're
still there. And the TV says it's a 16:9 signal and Zoom options are
unavailable. How come?
Also, www.titantv.com shows at least 7 HDTV broadcasts for the area where I live (Brooklyn, NY). How come I can get only 3 of them?
And finally, I'd like to be able to use firewire i.Link connection of the TV
to record video from it to my PC. When I connect TV to PC, Windows XP
recognizes the model - KDP-57XBR2, but asks for a driver for it. Do you know
where I can download one? If not, what is the work around to use i.Link in
HDTV to PC connection. I have used firewire with another SONY product with i.Link - DV camcorder DCR TRV-20 for a while with no problems, I'd imagine TV has similar interface. Also, direct firewire connect camcorder-to-TV doesn't work either, the TV detects the model of the camcorder but that's it. When switching to that i.Link TV says "No signal".
Thanks in advance for your help, I really appreciate it.
