Angelo.M
- Aug 15, 2002
Anyone using their iPod for jogging/running? Is it feasible?
Anyone using their iPod for jogging/running? Is it feasible?Well, yeah. I wouldn't have recommended the case I have or the iPod for runners and joggers if I hadn't used it for that myself. The case is very secure and I have yet to get my iPod to skip.
Checked out the Marware cases when I was in the market for a good one. I thought the thing was a little bulky unless you removed the lid and the anchor for the belt clip didn't seem terribly secure compared to the one on the leather XtremeMac cases.
2. How much better is the new MPEG4/AAC encoding?It's pretty good. Comperable to OGG in many ways.
I've decided 160kbps (VBR) is my AAC sweet spot. At 160 kbps it sounds as good as a LAME encoded MP3 (using --Alt Preset Standard). However, the file size is significantly smaller. About 25% to 30% smaller. You'll be able to fit a lot more on your iPod once iTunes for Windows is released.
What you notice when you change this is that ripping slows (on my P4 1.7GHz) from 12x (medium) to 5x (high) to about 1x (very high).Thanks for the explaination. I missed that last night.
Looks like it's just slowing the disc speed during a rip. I guess the thinking is that by ripping a slow spinning CD might be more accurate. I don't know.
There is another free CD ripper called EAC (http://www.exactaudiocopy.de/) that is known mainly for it's excellent ripping abilities. It reads each track twice then compares each read and will only convert to MP3 if the comparison is favorable. Due to that it is slower than CDex and it's a little more complex.
I keep both CDex and EAC installed and use both frequently.
