For a q=0.707 with no fill and no leaks and 0.1ohm series resistance, you need 62L.
For a q=0.707 with heavy fill and no leaks and 0.1ohm series resistance, you need 38L.
or just follow the white papers for the Shiva at adire.
..or get a linkwitz transform and put it in a box the size of an acorn
After factoring in some VC heating and reducing the cab by stuffing it with 3.0lbs of R-19 fiberglass, 2ft^3 plus driver and bracing. Call it a 16" i.d. cube.
Thanks guys. I downloaded the PDF file on the .7 Q design which suggests a 54L (1.9 cubic ft.) design. I'm not happy with the 3~4 cubic ft. vented box its currently in. Can someone suggest someplace to buy a pre-fab 2 cubic ft. box? I don't feel like building one By the way, how do I keep the filler material from getting on the amp? Is there some high-temp/fire resistant material I can staple over the amps internal circuitry?
thanks
Jim
3 places I know to get enclosures Link Removed (Kyle Richardson) Link Removed (Brian Bunge) http://www.geocities.com/hankbond1/index (Hank Frankenberg)
There are others, but these are the ones that I can think of at the moment.
Have you considered just plugging up the port, and putting some bricks inside the enclosure to soak up the extra volume? That would at least give you an idea of how the Shiva would perform without paying for an enclosure, and if you were satisfied with a smaller sealed enclosure, you could then go looking for someone to build it for you.
BTW, Parts Express offers 3 ft^3 enclosures, but they are pricey considering the raw materials involved.
http://quicksitebuilder.cnet.com/wrn...tics/id15.html
I built a 14" cube CNC machined for Bob at CSS and was shown at the NW DIY.
Running the RCM 150 AMP with a 6db boost at 35hz.
These cabinets will be up for sale in the following month or so.
Just getting all the info ready for Bob to post.
But the cost for a cabinet ready to assemble with 45 lock miter joints is very low on the pocket book.
And best you can assemble with or without clamps.
And ready for finish of your choice in 2hrs time.Just enough for the glue to dry.
These can be ordered with or with out driver holes and amp holes cut as well.
And a option for cutting a second cabinet volume is in the works as well.
Just by picking the dato you assemble the driver board into will give you different volumes.For different drivers besides the Shiva.
Good luck with you design.
Al
I had my Shiva in a 38 L sealed enclosure. I was not impressed. It was in an 85 L sealed enclosure prior to the smaller box. It is now in a ported 70 L enclosure tuned to about 20 Hz. Much better in a larger box. I was disappointed with the performance in the small sealed box.
No boost. The sound quality in a larger box is much better IMHO. Articulate, tight, deep are words that come to mind. I was just listening to a classic... U2's Achtung Baby..Track #12 Love is Blindness. Never heard that quality bass from the small sealed box. The Babbs don't sound too shabby either-95 dB at my listening position with peaks to 100 dB. Maybe with an LT you can get better quality out the the smaller boxes. And 70 L (2.5 ft^3)is not too far off from Jim's 2 ft^3 box idea. Don't get me wrong, the small box sounded good but the larger box brings the Shiva to life! Ask my wife, she can't stay in the room anymore!
