Van.L
- Sep 23, 2002
Hi, im just stuck on a little dilemma, I own a JBL 18” 1800 Gti 1000watt subwoofer and would like to buy a plate amp module to power it under HT conditions (movies/music) I also own a sony VPH-1271QM CRT projector... now my dilemma.. should i buy a 500watt RMS@4ohm plate amp to power the sub and not buy a line doubler for my CRT projector.. or should i compromise with a 350watt @ 4ohm plate amp module to power the sub AND GET a line doubler... the thing is i dont have much money so it would be either one of the two choices only unless justified =)). So should i compromise and get the 350 watt module with the line doubler?? Or forget the line doubler and get the 500watt plate module?? Any reason on your decision would be great =)) if you need any details for anything then ask away =)
Thanks in advance.
Van.
Thanks in advance.
Van.
