David-T
Grip
- May 26, 2002
3M is coming out with this neat new product called Scotch 100. You may want to look into this because you can use this in place of cable ties. The advantages are that it will not leave creases in your cable, you can reuse them when you expand your system or when you forget a cable in a bundle. No more cuts or scrapes and you can adjust the sizes, instead of buying several sizes of cable ties. See URL below for more info. They are suppose to be for sell at Radio Shack, Home Depot and Office Depot, but are not currently released. You want the continuous roll version instead of the perforated roll. I obtained a sample roll of this product and used it on my system and loved it. It has a smooth clean look to it, compared to cable ties and it does not bite into the cable as cable ties. It come in 1/4", 1/2" and 1" width. You may be able to obtain a free sample by calling 1-800-676-8381, but I can't guarantee that you'll be able to get a sample. Keep an eye out for this product because it is well worth it and if I hear anything else I will post.
Link Removed
Link Removed
