Eric_P
Grip
- Jun 22, 2002
Looks like it's good for most retailers
http://microsite.coupons.com/univers...SK&p=6SK3AOL61
hopefully best buy or someone will have it for fifteen on first dayI got a glance of tomorrow's Kmart ad today, and if I saw correctly Scorpion King will be $14.87 on VHS and DVD... Interesting that Kmart is diving into the loss leader business all of a sudden. You might end up having to price match elsewhere, as Kmart might only get fullscreen (or limited numbers of widescreen).
hopefully best buy or someone will have it for fifteen on first dayBest Buy will have Scorpion King for $16.99
Circuit City will have it for $15.99
Does anyone know if BB or CC accept manufacturers coupons.
$10.99 for Scorpion is definite buy for me.
Joe
Does anyone know if BB or CC accept manufacturers coupons.Best Buy does/should--I used a Disney manufacturer coupon at BB to buy Hunchback of Notre Dame...
Does anyone know if BB or CC accept manufacturers coupons.I was assured by the manager of the BB Media Department this morning that they DO accept manufacturer coupons. By then, I had already used the coupon at Walmart as they had SK for $14.86 - so final cost was $9.86 plus tax.
Of course, Walmart had their P&S version on the front of their SK display with the WIDESCREEN tucked/hidden off to the sides of the display! After seeing that, I *should* have purchased it elsewhere. Their support of P&S is ONE reason I usually shop elsewhere.
Of course, Walmart had their P&S version on the front of their SK display with the WIDESCREEN tucked/hidden off to the sides of the display! After seeing that, I *should* have purchased it elsewhere. Their support of P&S is ONE reason I usually shop elsewhere.At *MY* location, for *THIS* particular release (I'll emphasize that, since treatment varies from release-to-release), the distribution and placement was pretty even for FS vs WS.
But to show my support of WS, I made a point of dropping by the counter and finding a feedback card. I wrote on it "thank you for providing widescreen copies of Scorpian King; I only buy widescreen" (or words to that effect), and dropped it off where it goes.
Don't just buy the WS copy and expect Wal-Mart to notice the ring-up...lead them by the nose to it! Be VOCAL! Make sure they understand it was no accident!!
Of course, Walmart had their P&S version on the front of their SK display with the WIDESCREEN tucked/hidden off to the sides of the display! After seeing that, I *should* have purchased it elsewhere. Their support of P&S is ONE reason I usually shop elsewhere.Actually those displays all come from the company in this case Universal, and you just remove the cardboard around the display, set up any toppers and it's done, Wal-Mart is not the ones actually placing the Fullscreen and Widscreen in the areas they are in. I checked the numbers and for the store I'm at it was about 60 Fullscreen, to 40 Widescreen, not bad.
