I'm looking to upgrade my home theater receiver. I'm also hoping that in the process of doing so, that I can simplify my setup into something more wife-friendly.
My current equipment is as follows:Sony STR-K790 receiver
Optoma HD65 projector
2009 Mac Mini (using a dvi->hdmi adapter)
Sony PS3
A bit of what I do know about the different pieces of kit, starting with the Sony receiver. The sub is NOT self-powered. I had hoped to keep the unit's speakers but so far I've yet to find a receiver that doesn't require a powered sub.
The mac mini only provides video over the hdmi connection, but can send audio over an optical cable. I'm assuming most receivers will let me specify a 'device' that encompasses multiple inputs? For example, for the mini, hdmi->video, optical->audio.
What scares me a little bit about the mini, is that a year or so ago I tried to install an hdmi switch into the system but I couldn't get the mini to work with the switch. Mini->dvi->hdmi->switch->projector resulted in no video at the projector. I'm hoping this will work with today's av receivers but I mention it here in case anyone has experience with it not. I'm going to give the switch another try tonight, and will report back my experience in case I'm remembering it wrong.
In addition, I really like the idea of being able to do audio-only things without having to power on the projector. I see a lot of receivers have internet streaming capabilities. While the mini can handle all of these and more, I've yet to find a remote solution that works well enough that I don't have to turn on the projector to listen to music. If the receiver solutions are as simple as 'play pandora' then my wife will be very, very happy.
Summary:1) I want to be able to switch between a mac mini and a ps3, without unplugging wires.2) I want internet capabilities at the receiver for streaming music without having to turn the projector on.
3) I want the mini to connect via hdmi (video) AND optical (audio).
4) I'd like to re-use my existing 5.1 speaker set (albeit, if I have to buy a new powered sub).I hope I'm not forgetting anything. I've been researching for days and while I've learned quite a bit I'm not confident enough to make any purchases. My home theater is my living room, which is under construction and waiting for me to run speaker wiring so I'm feeling a little pressured to make some decisions. If #4 above holds true, I can get by with what I have until I fully decide on a new receiver.Thanks in advance for any guidance!
j5k
Sony PS3
j5k
