johnBrownsdream
- May 31, 2006
- john brown
some guy said it has poor bass preformance, those who have had experience with this receiver what do you think about that? Also can you recomend a70s receiver that is even better and more nice sounding than this one?
Lastly on older receivers where you have phono and auxilary, could you use these for other applications like if you had a plug to run you computer sound out into a receiver (plug has one end for the soundcard and two red and white wires for the receiver) or run the television sound to the receiver using either the phono aux or tape plugins on the back of old receivers like this?
If so can you do it with regular old red and white audio cords?
thanks
matt
thanks
matt
