Harman Kardon AVR 225 Sound from Radio Only, Cant select Digital Optical (1 Viewer)
Brandon_ND
This is old equipment i had in storage that i gave to a family member, it was very well cared for and rarely used.
a VIZIO E550VA television and HK AVR 225 Polk Fronts and center and a Cambridge sub.
Sound is working on all speakers if the radio is on, current issue was discovered when trying to set up the old VIZIO to run sound though the receiver.
Ran optical cable from SPDIF on back of TV to Optical 1. ( tried Optical 2, and optical on front as well) ( TV speaker is off in settings) ( you can see a red light emitting form the end of the optical cable)
NO sound, but cannot choose optical input when toggling, it skips over it.
We can get audio from a DVD player with audio connected to the CD input
Dont understand what the issue may be.
Any insight on what to check?
Is there a way to "reset" this receiver?
Jquick80
