StavrosRilling
- Dec 25, 2012
- Stavros Rilling
Hello everybody, I've hit a rut while tempting to install my new external speakers... Any help would be greatly appreciated.
So this is the basic setup:
-TV: Samsung led tv, model number un40eh5000f
-External speakers: Bose Cinemate II
-Cable receiver (Videotron here in Quebec)
-PS3
As the Bose manual puts it (and where my problem is), the tv only has an optical out (no red and white outs). So I have the optical cable going from the optical out into the optical in on the Bose receiver. That setup does not work. The tv settings should all be ok, I checked the manual and talked with two technicians.
I have tried taking the optical out from the PS3 directly into the optical in on the Bose receiver, doesn't work. The PS3 settings should also be ok. There are no red and white outs on the PS3.
I also tried taking the optical out of the cable box directly, doesn't work.
The only thing that has worked: red and white outs of the cable box directly to the Bose receiver.
So my conclusion is that the Bose system works properly. I also believe the optical cable is ok because a red light shows a its exit.
I seem to understand that the TV cannot serve as a go through for multiple systems into the Bose receiver... Either some anti piracy story or other depending on the forums I've looked at... In any case, I just want the system to work... So what do I do now? I'm not satisfied because the PS3 (acting as dvd and bluray player) doesn't work on the Bose system at all. Even if it did work directly from the PS3 to the Bose receiver, every time I wanted to change the source, I would have to move everything and change the cabling...
Is the only solution to bring back the Bose system and buy one that has a full receiver? As in a receiver that receives the full system from the source (image and sound) and then dispatches the sound to the speakers and the image to the tv?
I must add that I'm a beginner, simple words would be much appreciated...
Thanks guys, much appreciated, happy holidays, cheers!
-PS3
