Robin Smith
- Sep 27, 2000
Hi,
I am about to purchase a router, and am seeking advice from the woodworking types here who have used them for speaker making (one of my intended uses).
I have a few questions:
1. Do you need a plunge router or is fixed router sufficient. Is it a feature worth paying more for? What advantages would it give me that couldn't be solved with a well-placed drilled hole for starting a route.
2. Do you need avariable speed router? I am looking at sears models mostly (I have a gift certificate to spend).
3. Is a 1/4" router sufficient or should I go for a 1/2 router. How likely in the realm of speaker building and basic furniture building am I likely to need bits that require a 1/2" router.
Here are the models I am deciding between (all prices in Canadian $):
Craftsman 1/4" 9 amp variable speed (15,000 - 25,000 rpm) PLUNGE router - $179
Craftsman 1/4" 9 amp variable speed (15,000 - 25,000 rpm) fixed base router - $149
Craftsman Professional 1/2" 9 amp fixed speed, fixed base router - $189
I am tempted to go for the last one as it is probably an all round better machine but if variable or plunge is likely to be something I regret not having I may look further.
Any advice would be appreciated.
Robin Smith
Robin Smith
