gte357s
Grip
- Dec 24, 2007
- alex
Hi all, I would like to get your comments.
I am thinking to buy a Rotel RSX 1055 and B&W CDM 9NT speakers from an individual. My question is, should I spend another $350 for his Rotel RDV 1080 DVD player also. I read good reviews on it, but I think an DVD player is not a very crucial component, and a normal DVD player should sound just as good. I mainly use it for music. So, I am thinking if I should save that $350 and upgrade to Blue Ray DVD later. Do you think the music quality will degrade significantly without the Rotel player?
Thanks.
Thanks.
