Rj45 Wall plate needed (with a twist) (1 Viewer)
Matt Stryker
Land of the rolling tide
Matt
I'm wiring my house for ethernet next weekend, and I'd like to put a jack in the kitchen (there is an existing cable outlet, so I don't have to drill the hole). I'm pretty handy with a pair of crimpers and a punchdown tool (I do network support at work).
But I need a special wall plate for the kitchen. I need a RJ45 plate that has a covering (like exterior power outlets do) to prevent grease, food, etc from getting into the port.
Anyone got any ideas where to find them, or any vendor that specializes in wall plates? I checked SmartHome.com and didn't see what I needed.
Kevin P
I've seen plugs that fit over the RJ45 jack to protect it, maybe you can get one of those. As an alternative, just stick a RJ45 plug (with no cable crimped to it) into the jack when it's not in use.
Alternatively, can you locate the jack away from the part of the kitchen that gets greasy or wet?
KJP
DonRoeber
Would a downward facing one work? We use those for our wallplates at work. The cable goes in at a 45 degree angle.
Matt Stryker
Matt
Don- I'm actually going to use the downward 45s for the other rooms, but this one needs a bit more protection. The plug/insert idea sounds interesting....do you have a link Kevin?
webbhcjr
