I'm willing to pay any amount.Any amount? Are you sure? Some high-end home theater receivers these days cost over $3000.
It would help us out a lot if you could “narrow the field,” Natalie – give us a price range, some features you would like to have, perhaps some brands you like or don’t like, etc.
Wayne A. Pflughaupt
hehe, wayne, that there is quite an underestimation.Yeah, I know. Didn’t want to scare her too bad - $3000 is scary enough!
But I can see I didn’t scare her at all. Looks like Natalie's going for the gusto
Natalie,
If you can afford it, there’s no reason not to buy the best from Denon, Yamaha, Onkyo or Pioneer, to name a few. However, unless you have a use for everything these models have to offer – like inputs for five or six (or more!) video components, component video connections, Dolby EX, 6.1 inputs for SACD, etc. etc. - there’s no reason to shoot that high or pay that much.
Yes, 4-omh speakers are a problem with most modern receivers. You might be better off running the Vegas with a separate amplifier. You could easy connect one to the receiver.
Again, you would have better luck with a response if you could narrow the field some. I suggest visiting some dealers and talk to some salesmen. Narrow it down to 3-4 models. Post a question here about a specific model, and you will get lots of replies as to the pros and cons of each.
I’ll start with my personal favorite brand, Yamaha. Noted for their reliability, very sedated and handsome styling, IMO. Their current flagship, the RX-Z1, is something like $1000 cheaper than Denon's flagship 5803. It has more than enough power for your Vegas, and more inputs than you will probably ever use. Lots of great features, like excellent digital equalizing for most all the channels, bass test tones to help set up a sub, extra front effects speakers for Yamaha’s superb surround modes. Plenty of digital inputs. And on and on.
Wayne A. Pflughaupt
