Clay Autery
- Oct 23, 2000
I've just about decided to go for a flat black laminate (or a close as you get in that stuff) to finish my 6-shelf compnent flexi-rack. I got all the shelves cut and the holes drilled for the rods today, and I'm thinking that I just don't want to deal with lacquer undercoat and fighting the dust for several top coats... better to go with a glued-on laminate...
Here are my questions:
1) Should you a) laminate the edges first, trim with a flush bit, then laminate the flats, then trim with a flush bit or... b)laminate the flats, trim, laminate the edges, trim.
It boils down to where you want that thin trimmed edge showing I guess right (looking from the side, or loking down on the shelf).
2) Using 3/4" MDF, would it be a reasonable idea to relieve all of the edges just a bit (like 1/32" with sandpaper) before laminating? Just a thought...
3) I'm going to go look up the application process for laminates, but I was wondering what the best way is to insure that the glue in applied thinly and evenly enough to avoid bumps or bubbles AND with a working time long enough to position and roll the laminate for proper bonding?
Any other tips or tricks would be helpful... I've still got to build the wood "housings" to cover the rods on the bottom and provide a mounting place for the transfers, but I'll want to hit Home Depot (or other) soon thereafter.
