Brian Fineberg
- Sep 1, 2000
I am debating which one to get between the ts1000 and the tsu2000. Is saving money worth it because of the not preprogrammed codes?? can I just download entire remote codes for a component from remotecentral.com?/ If that is the case then I will go with the 1000. If it is more complicated than that then I will just pay the extra 100 bucks and get it preprogrammed. let me know ...Thank You!!
-B
-B
