Dan Whalen
- Sep 15, 2001
I've been reading some posts, and everything that I've read says that if you have a front firing sub that you should put it at least 12" away from a wall and fire it into the wall. I've got a problem with that though. I'll be putting the sub in a corner behind a chair, so I won't be able to fire it into the wall. At least not from 12" away. Maybe only a few inches. How do subs perform when they fire out into the room? Should I look into getting a downfiring sub, or would a front firing one facing out into the room work? This is the only place I can put a sub, so my options are kind of limited. I was looking at getting either a 10" or 12", but not sure what brand. Thanks.
Dan
Dan
