ThomasL
- Mar 13, 2001
I have an old Pioneer stereo receiver 100 watts a channel in my home office and I want to attach a Sony subwoofer that was part of the SA-VE315 package and which is currently going unused. Thisd sub has no crossover management at all as far as I can tell and I believe the specs list that it has an internal crossover of 200 Hz. My question is this.
If I daisychain the front speakers through the subwoofer does that mean:
(a) I have to have the sub on in order to get music out of the fronts?
(b) That when the sub is on it will only send signals ~200 Hz or higher to the front speakers.
My L/R speakers go down to 70-80 Hz (CSW Newton M50 bookshelf speakers) and I'd rather not have option (b) happening.
For now, what I've tried as an experiment is running both the mains and the sub from the receiver directly. I realize this will double? the load on the receiver but I only listen at low volumes (never get the volume higher than 1.5 out of 10). I also realize this will boost my bass in relation to the other frequencies since both the fronts and the sub will be handling a range of bass frequencies (say 80 - 200 perhaps).
One option that is not an option is to buy a new better sub with crossover mgt. since I'm only trying this since it seems like a waste for the Sony to go unused in the closet.
thanks for any help!
--tom
--tom
