SteveCallas
- Dec 23, 2003
Is using DVI output similar to using an optical cable, as in the dvd player doesn't process the audio information, just reads it off the disc and sends it to the preamp or receiver for processing? By using DVI output, does the dvd player only get the video information off the disc and send it to the projector or tv for processing?
Forgive me if this has already been discussed, but wouldn't it then make sense to purchase a relatively inexpensive dvd player that has DVI output if you have a higher end projector or tv?
