Brian J Dupuis
- Jul 8, 2001
Hey guys,
Little update on the 12" DVC, PE 250W, ~1 cubic foot project for those interested... just trying to "give back" to the community a bit with my experiences so far. If you're just looking for the questions, scan down to the bottom . Thanks!
http://homepage.mac.com/bjdupuis/PhotoAlbum1.html. I also have two 3" spring clamps. The box is set up as follows:
* top and bottom are totally outset.
* front (where driver mounts) and back are inset with respect to top and bottom, and outset with respect to sides.
* sides (one of which has amplifier cutout) are totally inset.
I'm thinking of gluing one of the sides and the back to the bottom piece at the same time, but place the other side and the front "dry fitted" together (for "squareness" and to give the clamps more to hold onto), then band clamping horizontally near the bottom and top and pipe clamping vertically the center and edges. After that's together, then I'll glue the 1/2" edge bracing (recommended by someone, I just can't find the post) on all the edges and then caulk up the glued edges. Once dry, I'll glue the dry-fitted front and opposite side and apply the edge bracing and caulk similarly. Once that's dry, I'll glue in the big braces and the edge bracing for the top, and finally the top, with fun attempts at caulking through the speaker and amp holes.
Does this sound feasible? Any advice?
Thanks again for all the info.
