Danny R
- May 23, 2000
I want to backup a directory to CD or DVD. The trick? The directory is 60 gigs in size. I do NOT want to manually format this directory into 700MB (or 4.7GB for DVD) chunks, but would rather the software do it, and do it in a way that the files can be simply copied off the CD's to a hard drive and still be in the same relative position to each other.
The problem I'm finding is that most software that burns to CD either doesn't support spanning over several disks, or uses a proprietary format so that you need the original software in order to get your data back. I want the CD's to be readable in any computer.
Anybody have a solution for me? Thanks!
