I need some help with a very specific digital 5.1 setup.
I have a Marantz AV600 preamp, which is Dolby Pro Logic, handles 2 VCRs, and it feeds 5 Marantz mono-block amps. I do not use a subwoffer (so far). I just acquired a Denon DVD with digital decoder, and I have a HD wide-screen digital TV.
What are my optimal options for getting 5.1 digital audio from all my components (DVD, TV, 2 VCRs)?
1) Should I go with the Marantz DP870 decoder? I would have to get it used. Then I have 2 decoders, and my VCRs are not in the LOOP.
2) Should I buy a new preamp with a decoder, an expensive alternative, and then I also have 2 decoders.
3) Is there such a thing as a preamp without a decoder, but with 5.1 channel inputs from my DVD and outputs to my 5 amps?
Thanks very much for any assiatance.
TonyJK
TonyJK
