Vince Bray
- Oct 4, 2000
How do you control the expanding glop when you're glueing the finish surface of a cabinet? Do you just apply the glue very carefully and try to not get it on the finish, or sand it off, use a solvent such as min. spirits? What works here? With yellow glue, you have to be careful since the glue won't take stain. Is that the case with the poly?
Thanks for your help!
Vince
Vince
