Mark_Be
Grip
- Dec 31, 2002
I have the following equipment and setup for my entry into the HT hobby...
Equipment:
Sony STR-K840P receiver
Sony micro speakers (SS-MSP2 for R/L fronts and surrounds; SS-CMP2 for center; and a Sony sub-woofer)
Setup:
Not optimal but I have to deal with a family room setting where the Panasonic 53" TV is in a corner of the room so the R/L front speakers are actually about 3 feet closer to the listening position than the center speaker or TV and the surrounds are directly on the side of the listening position. The front L/R and surrounds are on the floor. Distance for the speakers from listening position is about 15 feet for front right (left is about 2 feet closer)and surrounds are about 7 feet from listening position directly to the side. I have set the menu options on the receiver to match this as much as possible.
My problem is that the surround speaker effects seem to be more like pockets of sound or pinpoints of sound when the effects come from them instead of feeling like I'm immersed in the sound of the movie. Unfortunately, the only comparison I have to my setup is a friend's house where the setup and speakers are MUCH better quality.
Kind of hard to explain but my system gives the sensation that the effects "travel" from the surround speakers to the front speakers instead of just being a seamless flow of sound.
My question is...will an upgrade to better speakers help this situation or is the setup of the room really the biggest problem. Hopefully, speaker upgrades will help as that's something I can do something about but I'm pretty much stuck with the room setup.
I know from reading the FAQs that my setup isn't optimal but I wanted an opinion of whether the speaker upgrade will make a noticeable difference with regard to my problem.
Thanks again,
Mark
Equipment:
Setup:
Thanks again,
Mark
