Larry Alan
- Oct 12, 2003
I see everyone just glues their MDF for speaker projects. I have a pneumatic narrow crown stapler that really holds wood together almost as good as screws. The staples are about 5/32" wide and I have 1 1/2" long staples. The surface wound is very minimul and depending on air pressure, usually goes below the surface, leaving a tiny spot to fill.
Another question: Will ratchet straps work in place of the bar clamps. I have several ratchet straps but no long bar clamps. I was thinking of glue, staples, and straps for my project. Any thoughts?...................
Larry Alan
Larry Alan
