james e m
- Jun 3, 2001
So I bought a new cheap 32" tv to use for about a year when at that time I plan on buying an HDTV or projector. The tv, the Sharp 32U-S50 has only one s video input, but I have two s video sources (a dvd player and a Playstation 2). So the way I see it, I have 2 options and I need advice on which one I should choose. Keep in mind I am an ultra tight budget right now.
1. I can buy a 1 meter Better Cables Silver Serpent s video cable ($60) and run it directly from my dvd player to my tv. Although, every time I want to play the Playstation I'll have to unhook the dvd player from the tv to hook up the Playstation's s video cable.
2. I can buy two sets of 3 foot AR Master s video cables ($80). Then I would have the dvd player use one s video cable to run to my receiver (a Sony DA5ES) and run the Playstation 2 s video to my receiver and use the another AR Master s video cable to run from the monitor out on my receiver to my tv. Make sense? I hope so.
Does the Sony DA5ES do a good job with video switching?
So what I need to know is what would the better option will be? Should I go with the supposed better cable, the Silver Serpent or the more convenient option of the $20 more AR Master cables?
Your opinions are appreciated!
James
James
