Tim L
- Jun 30, 1997
I bought a new Reference 50 along with the 200.7 Amp back in the spring but have not has the chance to hook it up (moving-selling house etc). So this week I finally hooked and up and I have no sound from the right surround speaker. I did at first but very faint- now its nothing. I doubled check the speaker cables-connections- and also swapped out the cable from the Ref.50 to the amp ( I am using unbalanced connections) still no sound. While I ran the speakers through the test tones I noticed at first the white noise from the right surround was very faint compared to the other speakers- but that lasted about 10 seconds before it went dead. My question is do you think it is the amp or the Ref. 50? Just my luck- I use crappy equpment and they never die- I upgrade to the so-called good stuff and its dead out of the box-go figure. ANyway any help or info would be greatly appreciated- Has anyone dealt with B&K customer service before? seems I may be needing them. thanks
Tim
Tim
