Ted Ross
- Dec 13, 2001
Im trying to figure out what exactly Yamaha's cinema eq settings do on my RX-Z1. There are seperate settings for the L,C,R/front effect/Rear L R/& Rear CT-that part I can figure out-However, once one of the speaker groups has the cinema eq turned on, then its the 2 settings that become available within each speaker set that Im having trouble figuring out.
The 1st setting is a high-shelving equalizer with 1.0khz-12.7khz settings with a gain setting of -9db-+6db
The second setting is a parametric equalizer with 1.0khz-12.7khz settings with a gain setting of -9db-+6db
Each one of the speaker groups have the above 2 settings if the cinema eq is activated for that speaker group. Any help is appreciated!
