ChrisWiggles
- Aug 19, 2002
Good question, and something I didn't really address:
Yes, they are really the same thing. PLain DD/DTS 5.1 is the same thing pretty much. You can apply EX/ES processing to "regular" 5.1 soundtracks. Again keep in mind that "EX/ES matrix" tracks ARE 5.1.
However, the difference is that the soundtrack was not mixed and monitored expressely for EX/ES decoding, so the results, while they often should be quite good, may not always be good. For instance, you might have a hypothetical 5.1 disc with the two surrounds in mono. PLay that with Ex/ES, it will all be sent to the rear, and this certainly is an unwanted effect. So the only difference is that a disc that's labeled EX or ES *should* sound better with that processing applied, while a "regular" 5.1 mix *probably* will sound better, but you can't be sure.
It's very similar to a stereo track, versus a "pro-logic" track. Both are technically stereo, there is no inherent difference. However, the "pro-logic" track was mixed and monitored at the studio with pro-logic equipment, and designed to be played back with PL processing. The "regular" stereo mix was not, therefore your results with applying PL processing may be mixed on the regular stereo track.
The only technical difference on DVD besides the mixing methods, is that EX/ES titles can contain flags to trigger that processing automatically. Depending on your receiver/processor and options, you might have to enable EX/ES processing on regular 5.1 discs manually, while it picks up the flag and engages that processing automatically on EX/ES discs. Also, some discs are not properly flagged, or incorrectly labeled.
