Adam.H
- May 27, 2004
Display: Plasma: Pioneer PDP-5070HD.
Source: Pioneer DV-490V/S (Standard definition DVDs)
Video Output Setting: 1280x720p
The Warnings:
“Extensive viewing of content with top, bottom, or side masks may cause uneven wear. After viewing masked content, it is recommended to view full screen motion video for an equal or greater amount of time.” – PDP-5070HD manual, page 7
“It is not recommended to consistently display signals that do not completely fill the screen. This may cause temporary or permanent image retention depending on the frequency and duration.” – PDP-5070HD manual, page 69
My Problem:
While viewing standard definition DVDs, anamorphic widescreen / 16x9 movies, with screen size modes “Wide” or “Full” I am left with a small amount of “black bars” on top and bottom of the picture. The screen really only fills in “zoom” mode – but this stretches / distorts the image slightly. DVDs will be my only source on this plasma screen. Does that mean I need to watch everything “Zoom” (distorted) mode to prevent damage to my television? Should I be using a different video output setting on my player?
The Warnings:
My Problem:
