John Tompkins
- Aug 30, 2000
Hi, My name is John and I am an AMPoholic. Its been 5 days since my last amp. I have been through HK PA 5800, Carver 753 and 4.0T, Rotel RB993 and 985, NHT SA-3, McCormack DNA-1 deluxe, Sherwood 9080, Prasound 1201 monos, Sherbourn 5/1500, Citation 7.1 and I'm sure I am missing a few more. I normally would wait longer to evaluate, but I just cant.
Let me get the minor nit-picks out of the way. The inputs on back are a bitch to get to, The binding posts are configured in an up/down manor{you better use bananas} and it seems to run fairly hot.Probably because its so big that I only have an inch or two clearance on the sides. Also it hummed and I had to use a cheater plug.
I knew from about 10 minutes in that this was my last amp. Music listened to Creed, tina Turner, AC/DC, Alisdar Frasier, Sarah McGlaughlin, Blues travelers, Days of the new.
This amp is DYNAMIC, the bass is rock hard and well defined, the mids are sweet and the treble is revealing and not in your face at the same time. I cant explain it but normally when I get a new amp, it seems some type of music isnt right or something is wrong,not so with this amp. I normally have to reposition speakers, move my seat, shut bedroom door etc. to tell myself an amp sounds good. This amp just took over,,,I cant read the volume on denon 4802 so I just turn up volume to comfortable level...I had this thing at -5db, didnt realize it untill my wife came in screaming to turn it down and I couldnt even hear her.
It didnt break up at high volumes, never was harsh and had a sweet quality about it.
This amp is a great match for my NHT 2.9, by the way I had the speakers bi-amped with 4 channels..
My amp sluting days are over. I cant expain it be most of the time if an amp is revealing, it seems bright to me, This amp is revealing at the same time not bright. Drummers beats rock my chest, and symbols sound so clear. Strings are incredible clear. My nhts woofers were moving harder then they ever had. Sarahs voice was so calming. RAVE, RAVE, RAVE ...I hope this helps some nht owners try this before going through a thousound amps....Thanks
