Manuel Delaflor
- May 25, 2001
I have the speaker out from my integrated amp directly attached to my mains, but I also use another set of cables from the speaker out of the integrated to the high level inputs of my sub's amp to feed it (I get higher dB's by connecting the sub this way instead of using the pre-outs).
My question is if I can use the high level outputs from the sub's amp to feed another set of drivers? (in particular some tweeters with its own crossover)
My main concern is that they are only 4 Ohm's. In case you wonder why do I want to do this is because I want to experiment by putting the tweeters on the back of my mains trying to replicate the sound of a dipole.
Im just experimenting, for the fun of it, but want to be sure I won't damage my amplifier :b
