Joseph DeMartino
I was able to pick a factory refurb for a song, and figured it would be good enough to replace my old pre-HDTV Denon receiver without breaking the budget in my new (smaller) home theater. I don't even have the surrounds installed yet, but I was playing around with it just to get used to the settings and discovered something odd.
Since the Onkyo has only component video inputs and outputs, no HDMI, I've connected my Sony DVD changer and my cable company's Scientific Atlanta HD-DVR to it via component, and then connected the component out to my 56" JVC HD-ILA RPTV. As before, the TV automatically adjusts the aspect ratio between 4:3 material and 16:9 HD shows. But it no longer does with the input from the DVD player - which it did flawlessly when the player was connected directly to the TV. Since the whole point of updating the receiver was to use it as an audio video switch, this is unacceptable. Am I doing something wrong? Is there a problem with the receiver? I haven't changed any settings on any of the other components, the Onkyo does not have an On-Screen display and the manual offers nothing useful. Any ideas? Or should I just bite the bullet and save up for a receiver that handles HDMI switching? (Assuming there is such a beast.)
Joe
Joe
