Bipin_P
- Mar 2, 2002
Anyone know what chipset this unit uses for deinterlacing?
DVD-Audio, with its rich, enveloping sound from 5.1 channels, or Super Audio Compact Disc (SACD), with its frequency response of up to 100 kHz and sampling rate of 2.822 MHz? The debate over which provides the purest and smoothest musical experience is still raging. Fortunately, the DV-SP800 lets you make the final decision by providing you choices other companies can only dream about. But it doesn’t stop there. Few DVD players on the market meet the rigid standards of THX® Ultra certification; the DV-SP800 not only meets these standards, it exceeds them. Onkyo’s exclusive ExperienCinema™ concept provides you with the finest visual and audio experience through Progressive Scan, Direct Digital Path, 192 kHz/24-bit audio DACs and Vector Linear Shaping Circuitry (VLSC). DVDs are further enhanced with lossless 108 MHz/12-bit D/A video processing. Life is about choices. The DV-SP800 could very well be the last player you’ll ever have to choose.Perhaps Onkyo has developed its chipset. I'm not sure what ExperienCinema™ entails.
Perhaps Onkyo has developed its chipset. I'm not sure what ExperienCinema™ entails.I doubt that very seriously. Onkyo usually piggybacks on Toshiba for it's DVD hardware. I wouldn't be surprised if their deinterlacer is one we're already familiar with.
I'm interested on it's innards as well, specifically is SACD capabilities.
Troy
The video is very good as well but you must understand I don't have a HDTV yet so I use only the interlaced video. It is better than the Pany A110 it replaced.Charles, just earlier you said that the video was better than Pany A110; then you read the shoot out and now you want to switch to Pany again and return the SP800?
If you read the shoot out it says most DVDs will produce subtle differences in various players; definitely the video based and improperly flagged ones will look better on the DCDi players - again the question is if you watch a lot of video based material.
Kevin - the shoot out results for 47Ai are disappointing definitely but can you really see all those nuances in your rig? Before the shoot out you thought the picture was excellent but after the shootout have you been able to see any specific problems? I think 4 of the tests have got to do with CUE but if you are not seeing the same, does it have the same weightage? can you reproduce the chroma delay in your environment?
