Mike*HIN
- Jul 8, 2003
Hey all,
Been reading here off and on for a few months just never posted. So please forgive me if this info is posted elsewhere. I looked around but there is a lot of info here!
I got a 1999 model Toshiba television, model CZ27V51. It's my primary television. I'm not huge into home theater as I don't have too much money so that is the reason I have an older set. I also use a Toshiba SD-V290 DVD/VCR via component (Colorstream in Toshiba terms) video. That combo unit is a new model that replaced an aging SD-1600. Dolby Digital is from a just as old Sherwood, can't recall it's model.
A couple of weeks ago I finally found out how to get into the Service and Design menus. I have written down all the default values. I did a search on this forum for info on that particular Toshiba television and didn't come up with much except for some posts from a moderator here who has that set as his bedroom tv. I didn't expect to find even that much since this is an "old" set by todays standards.
I wanted to get into the service menu as this set has always been a bit too red for what I want. I fixed that just fine. The part I have not been able to fix is the horizontal overscan. There is a setting called "WID" in the service menu that doesn't do anything at all. I fixed the vertical overscan just fine.
Does anyone know by chance if there is another setting in the service or design menu on how to fix this? I've searched quite a bit over the net and found some references to others with this model where "WID" does nothing.
Maybe the moderator here who has this set in his bedroom can shed some light on this? And maybe if they or someone else has any recommendations for settings on this particular model.
Thanks in advance for your help!
--Mike
--Mike
